weird effect of NI SPY
Hi, all,
I am a prober/handler GPIB driver developer. Recently, I encountered some weird issue with NI SPY.
In my code, the following statement will send a command from tester to handler, the error handling statement will be executed when there is a bus error.
 ibcmd(0, cmd, 2L);
 if (ibsta & ERR)
  printf("SQR waiting Error\n");
  ibonl (dev, 0);
When the code is run at the production line, it is observed that: when NI SPY is open and capturing, the statement will never be executed, which means no error occurs. However, without NI SPY, the ERR handling will occurr like 5 in 300 runs.
Anybody has such experience? what is the effect to run NI SPY during GPIB communication?
Thanks.
regards,
Shi Chao
(3,415 Views)
Hi
One effect is: it slows down the communication a bit and that can be sufficient for this difference with and without NIspy
greetings from the Netherlands
(3,413 Views)
Hi, Albert,
Thanks for the advice.
If the slower speed helps to relieve the bus error, does it mean that I can lower the GPIB bus speed setting in MAX tool to get better performance?
regards,
Shi Chao
(3,403 Views)
