visa32.dll is not found?why?
I copy the file visa32.dll into c:\windows\system32, and refrence it in VB,
but VB report "visa32.dll is not found"
why?
(12,504 Views)
Just copying visa32.dll is not enough.  You must install VISA library on the target PC by its setup program.
In fact, the direct VISA dll interface to your app is visa32.dll, but it is not working alone.  It normally has much dependency to other dll components so that it can be correctly loaded. This is why you must install VISA library by its setup program.
(12,486 Views)
thanks!
after I run visaruntime.exe, all is right!
but this make ourself setup program some difficulty or inconvenience.
(12,481 Views)
makoto, when we install the visa-run-time, how do we select language?
the list of  files are following:
NIVISAruntime.msi
NIVISAruntime_chs.mst
NIVISAruntime_cht.mst
NIVISAruntime_deu.mst
NIVISAruntime_fra.mst
NIVISAruntime_jpn.mst
NIVISAruntime_kor.mst
TIA
(12,458 Views)
can you translate your solution into chinese,please?i cannot understand it correctly。thank you for your attention
(9,914 Views)
If you want to communicate in Chinese, go to http://forums.ni.com/t5/NI-LabVIEW-CVI-%E6%95%B0%E6%8D%AE%E9%87%87%E9%9B%86%E7%AD%89%E4%BA%A7%E5%93%...
(9,908 Views)
NIVISAruntime.msi
Whatever you want. The functionality of VISA runtime is all equivalent regardless language. Languages are concerning to VISA configuration GUI such as NI-MAX. English version will work on any Windows language versions.
(9,903 Views)
