viWrite succeeds but viPrintf fails
I am using GPIB to communicate between a PC (Keysight B1505 running Windows Embedded) and a remote host (wafer probe station connected to Windows XP computer).
In Keysight's Connection Expert software I can see the instrument is connected. When I use Keysight's Interactive IO I can communicate with the wafer probe station. For example, an "*idn?" command will return the expect string from the probe station. However, when I try to run a "full routine" in Keysight's software, the connection will timeout waiting for a response from the probe station. For example, I see a "*OPC?" command issued with the method viPrintf will timeout after 10 seconds. Just using Keysight's Interactive IO I can issue an "*OPC?" query that will succeed (not timeout). Using the interactive IO I notice this uses VISA::viWrite rather than VISA::viPrintf.
The same code was previously working, so I know it is not a matter of increasing the timeout. I suspect it may have to do with line termination as some settings there may have been changed.
Do anyone have any insight into this?
(1,087 Views)
Since the commands seem to use all a \n as termination character it may be actually useful to configure for that device the according termination character in NI-MAX.
In your image IMG_5356 try to set the EOS Character value to 10 instead of 0
Rolf Kalbermatter  My Blog
(1,025 Views)
