using ms2001 Monochromator of SOLAR TII
Hi Guys,
I am new with LabVIEW,
I just recently attended the LV Core 1 and Core 2.
I want to use ms2001 Monochromator of SOLAR TII. (manual attached)
the manual says that -
"System control
Central control by on board CPU
External control by hand controller (optional)
Programmed control by external computer
External interface RS-232C"
I could not find any driver for the instrument in NI.com/idnet
I have contacted the manufacturer of this device and they sent me a lot of files (see attached folder.zip)
I understood that the VI's are using the "Call Library Function Node" to call ms2001.dll and the Devctrl.dll
I wanted to use these VI's but when I am connecting to the instrument via RS232 and running the VI I don't see anything happenning.
What am I doing wrong ?
I have the list of functions of the Devctrl in the DevCtrl_SDK.pdf
should I try to run the dll's functions using the "Call Library Function Node" independently ?
(3,336 Views)
Since this instrument has a RS-232 interface, that is how you will communicate and thus control the instrument.
Before going hot and heavy into using LabVIEW and calling DLLs and whatnot, I suggest that you use something like Hyperterminal to communicate with the instrument. This will make sure that you are using the right serial cable, etc.
(3,326 Views)
