using NI interface under Liberty Basic
The parameters ... are well defined in this manual, but are "viOpen" or "viOpenDefaultPM" the strings I should be sending the dll to access these functions?
It seems to be a sort of syntax shortcut in LB, stricly speaking you only send parameters to the dll when calling a function, but you don't "send" the function name, just call the function.  If I understand the syntax
    calldll #lj, "GetFirmwareVersion", gv as struct, reply as double
means calling the function GetFirmwareVersion passing the following variables as parameters. Still I don't see where the type of the function return is specified (this one is void I suppose?), you will have to study it because all Visa functions return a result code (you can't just "ignore" the result in the declaration, any mistake in a type specification will result in stack unbalance and possibly a crash of your app).
Anyway it is easy to understand the VB syntax given in the manual (easier than the C syntax which is using some NI-specific type definitions probably hidden somewhere in remote NI header files), for example in :
viOpen&(ByVal sesn&, ByVal rsrcName$, ByVal accessMode&, ByVal openTimeout&, vi&)
& and % are implicit type indicators: & for Int32 and $ for string,
therefore viOpen& is a function returning an Int32, the first parameter sesn& is an Int32, rsrcName$ a string etc.
Byval means passing parameter "by value", as far as I remember if it is not there it means that the parameter is passed "by address" by default (i.e. passing a pointer to the variable).
You will need to find the equivalent syntax in LB for all these cases, i.e. how to specify the return values and how to select value/address mode. For strings you will need to search how to pass "null-terminated" strings (LPSTR type in C).  Once you have all this information everything will become trivial.
Message 11 of 13
(557 Views)
Message 12 of 13
(538 Views)
Did you look at the visa32.bas file in this folder: C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Include
Should help work out which data types to use
Message 13 of 13
(531 Views)
