usb to usb through d-sub
I have an instrument inside a vacuum chamber that needs to be connected to an outside PC through a USB cable.
However, the vacuum chamber has 9 pin D-sub feedthrough only. Is there a way to get the USB connection going through the d-sub? (i.e. an adapter to connect the USB to the D-sub inside the chamber and another adapter to connect the D-sub to USB outside the chamber).
Thanks.
(3,753 Views)
The NI USB-232  should fit your application
Justin E
National Instruments R&D
(3,733 Views)
Hi
I don't think a usb to serial converter is what is needed.
You probably can wire the 4 pins of the usb connector to 4 pins of the subd connector.
Be careful to keep the wiring as short as possible. especially for the twisted + and - signals. The power is not a problem.
And maybe an option to shiled the two information wires with as much ground around their positions but keep the signals next to each other (no ground inbetween)
greetings from the Netherlands
(3,730 Views)
