usb-488 device won't load drivers
i have a usb-488 device that i am trying to install onto windows xp.
the last computer that the device was connected to died recently, so this is a fresh install.  but i can't get the drivers loaded and have tried everything.  everytime, windows says that it can't find a suitable driver for the 'usb device'
the drivers on the other machines in our lab are:
GPIB-Interface
date: 1/1/2006
version 2.5.0.3055
driver:  windows\system32\drivers\nipalusb.sys
ni-pal usb wdm (1.4352.3.0)
any ideas out there as to what i can do ?
i have installed the NI488224 driver pack, as well as a bunch of other drivers / installers onto this machine in hopes that something would have the correct items, but i have had no luck.
(4,163 Views)
Exactly which model of USB-GPIB are you using? Is it in fact from NI?
(4,145 Views)
Hi Egiblock,
If it is indeed a NI GPIB-USB device, then this KB addresses the problem you're reporting. You might also want to upgrade to the latest version of NI-488.2 2.8 linked here.
Best of luck!
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(4,111 Views)
it was actually not a NI controller.  whoops.
(4,077 Views)
