hi all,
I am a newbie at labview. Currently, I am using visa3.0, ni 488.2 version 2.0, and the vi library
hpesgdxx.llb from the hpesgd.zip driver set I download
from national instrument, and the gbip-usb-b connector to interface with my digital generator, the hp e4432A-1e5-un4. The problem I am having with this is I attached a waveform generator to the ext 1 input of e4432A, and set fm source to ext1 AC-coupled. In the subvi hpesgdxx config fm modulation.vi file, I even changed the fm source to ext1 1. Then when I click the run arrow hpesgdxx getting start.vi, the fm source on both the digital generator and and hgesgdxx config fm automatically changed to internal 0. It doesn't seem to accept input f
rom the waveform generator connect to the ext 1 input. (the waveform generator I used is agilent 33120A). Can anyone give me some feedback.
Thank you
