suggestion for serial communication thermometer with ASCII commands (for teaching purposes)
Hi everyone,
maybe off topic but I can't find good answers on google.
I am teaching basics about LabVIEW programming to students and I would like to make an exercise where they have to create a small simple interface to program an instrument (select chan num XXX, start reading with interval...) and continuously read answers from the instrument, extract data, plot it on a graph and save in log file all inside some parallel while loop... Nothing fancy, just the basics.
I therefore looking for a "cheap" (around 200 euros) digital thermometer with 1 or 2 channels (RTD or thermocouples) which has a digital screen display, a serial port rs232 for communication with the computer based on ASCII commands and a good documentation which describes communication protocols parameters and lists of ASCII commands, because I want the student to spend a bit of time looking for the information in the documentation but it has to be done within reasonable amount of time.
A great thermometer for that is the ASL F200
https://www.isotechna.com/F200-Precision-Thermometer-p/f200.htm
but it s a bit pricy for my use here and I don t need such accurate instrument.
Maybe someone has good suggestions for me
thanks a lot
regards
Hicham
Message 1 of 14
(5,330 Views)
https://www.omega.com/pptst/MDS8PT.html
If you know what you want, you may be able to get a refurbished instrument on eBay.
Message 2 of 14
(5,296 Views)
You could try the CL3515R from Omega.  It has a Serial or USB interface that allows for remote configuration and monitoring plus is close to your 200 Euro price tag.  It has two input sensors and can even drive an output to be used as a calibrator.
https://www.omega.com/pptst/CL3515R.html
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 3 of 14
(5,286 Views)
Dear Minions,
I'd like to purchase that thermometer (Omega CL3515R), from which I'd like to read from my own program.
For that purpose would you know of the coding for the RS232  interface?
Best regards
Message 4 of 14
(4,989 Views)
A little off topic, but have you considered using Arduino Uno as a teaching tool.
They cost around 25 USD.
Here's a link to some LabVIEW/Arduino projects
https://create.arduino.cc/projecthub/projects/tags/labview
Just a thought
Curt
Message 5 of 14
(4,972 Views)
I do know the command set used with this device.  It is provided in the instruction manual that accompanies the CL3515R purchase; even though, it is not as clear as desired.
Message 6 of 14
(4,926 Views)
Here is a breakdown of the Remote Programming Commands for the CL3515R:
<COMMANDS>
%001 => Default ID (until redefined by the %001Ixxx where xxx is some 3 digit number like %001I012 => New ID will change from 001 to 012 when using more than a single CL3515R unit) All other commands and queries below shown with ID 001.
%001P+011000 => New Output Setpoint for Temp will be +1100.0
%001TK => Set to use K-type Thermocouple
%001UC => Set to the Celsius Temperature Scale
<QUERIES>
%001a0 (-a9) => Meter Group Addresses
%001b =>
%001d => Read both Thermocouple Inputs
%001e => Read both Thermocouple Inputs
%001i => Read (ID)
%001p => Read Output Setpoint
%001t => Read Thermocouple type setting
%001u => Read Temperature Scaling
%001v => Read Firmware Version
This device also has a power saving mode and will automatically turn-off if no commands are received after a period of time.  Use a 9V power adapter and periodically send a Read ID query to keep the instrument awake until needed.
Message 7 of 14
(4,909 Views)
Can you also provide the port settings
Message 8 of 14
(4,620 Views)
The CL3515R unit can connect to a PC through a USB cable to custom interface RS-232 connector on the CL3515R unit.  Most units come with this cable included.
Message 9 of 14
(4,615 Views)
Can you let me know where to find the document for talking to CL3515R under serial port?
I would like to control it under Mac using python.
<COMMANDS>
<QUERIES>
%001b =>
%001i => Read (ID)
Message 10 of 14
(4,436 Views)
