serial data read out interfacing
Hai i'm new in labview programming and try this language in my project. My problem is error for my interfacing with Canberra dual counter 512 as (Error 1073807298 occurred at visa in Basic Serial Write and read with warning suppression). anybody please help me..thanks for your assistant
(4,376 Views)
Hi Zainu,
The same error occured when I used my USB <--> RS-232 converters the first time.
Solution was to add the buffer function (once) after you configure your serial port.
(4,376 Views)
What'r you means add the buffer function (once)?
(4,370 Views)
Sorry that was a bit short.   Smiley Tongue
In the serial interface pallete you will find a 'VISA Set I/O Buffer Size' function.
This function solved my problem writing to my USB <--> RS-232  device
(4,364 Views)
I have anothe r problrm when i want to install my LV 8,2 NI device driver, what should i do..as below
Legacy NI-488.2 Software Detected
A legacy version of NI-488.2 has been detected.  You must exit this installer and uninstall the legacy NI-488.2 software before you can install this software.  To continue without exiting, you must deselect the NI-488.2 feature.
(4,093 Views)
Just what it said. Remove the old ni488 driver by hand, remove it from the controlpanel/add remove programs place
greetings from the Netherlands
(4,090 Views)
hi, tq Mr. albert, i'm very happy to hear suggestion from you.
actually i already install device driver for advantech for previous project. is it gpib is old one  ( 2002)? that ni  Labview 8.2 conflict with
(4,064 Views)
