serial communication
I  have done a Serial Communication connection through LabVIEW  using RS-232  by short circiuting pin no. 2 and 3 of the 9 pin male (COM port)connector and using the read and write buffer ,at that time its reading the data whatever we write into the buffer.But  now I am using the same procedure to analyse the  output of the microcontroller PIC 16F628A by feeding the output signals Rx & Tx from microcontroller directly to the pins 2 & 3 and into the read  buffer,  now its showing some error (as indicated in the attachment).So,please suggest me accordingly.
(3,642 Views)
This means that the serial port selection was not correct.
greetings from the Netherlands
(3,635 Views)
I  am using the same Serial port as used earlier for reading and writing data through the buffer.
(3,597 Views)
