This widget could not be displayed.
serial communication error
dear sir
i have developed a program to read and write a data from a controller using labview VISA. Eventhough i have configured the visa. i have the error can anyone explain how to solve this in detail... and the error is
Message 1 of 10
(5,808 Views)
save your vi after you have made all current values default (edit/make current values default) and post it to the forum as attachment.
You probably made a simple basic error but there are a lot possibilities to choose from.
greetings from the Netherlands
Message 2 of 10
(5,805 Views)
Accepted by topic author steps
thank you sir for your kind reply. i have attached my program along with this mail..sir can you tell want is exact in the program
Message 3 of 10
(5,802 Views)
Hi
You did not save with real values (or at least did not make current values default)
This frontpanel has no filled in values so cannot work.
You probably miss a while loop between init and close so I added this
Furthermore I changed read and write control into pushbuttons.
and added a possibility to clear the read string
Message 4 of 10
(5,788 Views)
even though i set the parameter in the front panel like ( visa name = com1, baud rate=9600, data bit =8, parity=none, stop bit =1, flow control =none.) error is occuring sir..... and one of my friend said you need to declare IDN for serial communication .. i dont have idea about IDN ... whether it is the cause of the error
Message 5 of 10
(5,785 Views)
sir one more doubt
 i did three three different program
in my main front panel i am decided to keep three tab and when i click the first tab in the main front panel, first program should run and the front panel for the particular program have to be displayed and when i chick the second tab second program have to displayed and so on ... i am new to the labview can you tell how to program like this  ....
wit regards
sathish
Message 6 of 10
(5,782 Views)
IDN is in some controllers a message to which they react with sending their identification and version.
You did not give any information about your controller so helping is very difficult.
I don't understand anything about tabs and programs so please clarify your question.
Did you run my version?
What error occurred?
Message 7 of 10
(5,778 Views)
good morning sir ,
                i am using PIC microcomtroller.i run your program but now also same error occuring .... can you explain what to do .. and the error code and error is given below.
1073807330 The specified state of the attribute is not valid, or is not supported as defined by the resource.
Message 8 of 10
(5,763 Views)
one of the parameters you are setting is not accepted.
So try out which one, by switching the debug lamp on and see where the error occurs
Message 9 of 10
(5,755 Views)
Thanks for you help, really apreciated 🙂
Message 10 of 10
(5,730 Views)
