scan from string
where can I find "scan from string" in order to use it tu read more than a byte from a buffer in Visa read?
thank
(3,878 Views)
Related to this
(3,870 Views)
it doesnt work I send "^Q" and the loop doesnt stop and the VI  dont recieve it.
I have 2 serial port and I am using digicom to send   ^Q
can you please test it
thank
(3,862 Views)
If you are refering to the modification I made, it does work with LabVIEW sending or with Hyperterminal sending. I am not going to install a program that I do not know anything about. I would suggest you run the modified VI, send your string, and do a screen capture of the VI that shows data in the string indicator.
p.s. Also noticed in your original VI that you have the termination character enabled. This should not be related to your problem but you could turn it off.
(3,859 Views)
I take back what I said about the VI working here. The VI I posted was not the one I used to test. I changed the > function to the >= but did not save it before I did the attachment.
(3,855 Views)
I have seen it
thank you for your help
(3,834 Views)
