same name USb device
Hello Experts,
             I am usingtwo USB frame grabber and want to use the USB aquisiation VIs for my application. but the name of both the USB devices is same and i want to switch between them. any expert comment will be highly appreciated. i am thinking of changing the USB device name but dont know how to do it, any other clue will also work.
thanks in advance.
cheers
harry
(3,308 Views)
Windows can distinguish between 2 usb devices with the same name by their usb connection path.
But several drivers can only handle one device. Sometimes it helps to plug the devices on separate controllers
(e.g. front and back of the pc sometimes have their own controllers) Otherwise you have bad luck.
greetings from the Netherlands
(3,282 Views)
