remotely controlling a signal source (RS SMB 100A) using GPIB.
I am trying to control a signal source (RS SMB 100A) using GPIB. To start with I am trying to writes small VI just to see if it allows me set various parameters (Amplitude, frequency, modulation etc). I am getting the following error:'Error 1073807194 occurred at RSSMB Initialize.vi'. Possible reason(s):(Hex 0xBFFF00A6) The connection for the given session has been lost. Can I have some help please?
(4,392 Views)
Maybe you can post one of the small vi's?
And we can see if you use visa or gpib itself.
greetings from the Netherlands
(4,343 Views)
Thanks Albert. I think it was something silly and I pretty much rebooted the computer and it worked. I would however, like to ask a slightly different question. I am currently having a GPIB connection between the signal source (RSSMB100A) and the computer (GPIB to USB). I actually wanted to do it through USB (there is a USB type B on the back of the instrument) but the connection was never recognised by the computer at all! Do you think I should have done something else apart from just connecting  in the first place?
(4,323 Views)
I do have VISA library installed which I think should allow all types of physical connections (LAN, USB, GPIB).
(4,322 Views)
You should install the USB driver from the vendor. That's assuming that the vendor has a driver for USBTMC.
(4,315 Views)
Or the intrument vendor should open up all the details of this connection and you would have to experiment with all nitty gritty details of the bus.
I agree with Dennis, try to get the usb driver from the supplier.
(4,311 Views)
