12-21-2008 03:37 PM
What does a red dot inside a circle in the [N] square of a for loop mean? (see attachment).
And how would one go about finding this out from the documentation?
12-21-2008 04:14 PM
12-22-2008
11:32 AM
- last edited on
08-12-2025
05:01 PM
by
Content Cleaner
Hi PointOnePa,
More information can be found in the LabVIEW help file: Adding a Conditional Terminal to a For Loop
Kevin S.
12-23-2008 02:54 AM
12-26-2008 12:27 PM
Hi Albert Ge,
That is correct. If the conditional stop terminal is used on a For Loop, and a True is read and passed to the stop terminal, all of the code within the loop will still execute before the loop terminates. (The same code sequence as if you were using a While Loop.)
Kevin S.
