"Error -363011 occurred at myRIO v1.0 Write I2C.vi"
I'm new in Labview and MyRio.I want to read the data from the differential sensor pressure SPD610-25Pa [https://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/8_Differential_Pressur...] using MyRio.
I try to read itvia I2c (expressvi) and I receive the following error: "Error -363011 occurred at myRIO v1.0 Write I2C.vi"
How to get data from sensor?
Thx
(3,422 Views)
Hi there,
the error could be generated for multiple factors, not proper wiring, pull up resistors, bad register reading/writing...
Here you have some links to forums where several of these problems where solved.
https://forums.ni.com/t5/Academic-Hardware-Products-NI/Error-363011-in-I2C-Express-VI-with-myRIO-190...
https://forums.ni.com/t5/Academic-Hardware-Products-NI/Error-363011-occurred-at-myRIO-v1-0-Wrie-I2C-...
(3,385 Views)
Dear ptr8911,
I'm particularly interested i your case as I'm facing the same problem with a SENSIRION temperature sensor.SCC30-DB.
I know this thread is a bit older than expected for a direct answer, but I post it here in case you are receiving a message and have something to share.
Did you finally any trick of solution to this problem?
I have checked some of the hints that are referred in similar threads, but for the moment nothing worked.
Thanks for your help, in any case
Iñigo Adin
(2,593 Views)
