quirky GPIB-USB behavior - visa session connection lost
Has this been fixed yet, e.g. by a new VISA layer?   Has this been acknowledged by NI as a VISA layer bug? I've been having this problem in two stations and not in a third one, all running identical software, the difference being that the one where everything works has a PCI GPIB card and the ones where the code fails have GPIB-USB adapters.   I'm not particularly fond of replacing that part of the code to use GPIB calls, but may have to.
Message 11 of 13
(1,479 Views)
Hi instrumento,
There were some issues improved/repaired in some of the later versions of NI-VISA.  Have you upgraded to the latest version?  If not, you can find it here.  What version of LabVIEW and VISA are you using when you see the problem?
Chris R.
Message 12 of 13
(1,453 Views)
I'm running VISA 4.0, Laview 7.1.   Seems to be a timing issue with a certain peripheral, when calling VISA Status Byte (waiting for SRQ) in a loop.  We have a delay before the first call to VISA STB, inside a while loop, and another delay inside the while loop.  By increasing those delays we seem to be able to survive, or diminish the probability of VISA erroring out, at a great cost to execution speed later on in the process.  Seems to always happen when I have another VI open with an image preview, through IMAQ, i.e. camera is streaming and I'm getting an image and putting in the front panel of a VI, where the camera is attached to a NI PCI based frame grabber.  The other VI is moving a stage over VISA/GPIB in jog mode via pushbuttons, and eventually one of the moves causes a VISA connection lost to the stage controller.  On the (identical) system with a PCI GPIB card the problem never occurs, or is so infrequent that we never seem to hit it.   If the video is not streaming I don't recall ever having problems, but I'm not 100% sure on this.
Message 13 of 13
(1,446 Views)
