problemes de block input error 8753b
hello!!
I realize a control on a hp8753b.
everything goes well for communication or change states, reading certain parameters.
d like to send datas and display the curve.
j I wanted to test the save and recall VI. for hp 8753b .. has no problems reading it and saves it to a file.
but when I want to send the vi m indicates a timeout and hp8753b and blocked
I have to reboot
please help
Message 1 of 12
(4,253 Views)
Hi
Thanks for posting.
But for me it is not clear what is really your problem.
Please give me a better discription of your problem.
Corné Westeneng
NI-Netherlands
Message 2 of 12
(4,234 Views)
hello,
My plan is to rebuild a program simulator cable with labview and hp8753b.
j have the basic program.
I manage to control the 8753b, send and receive datas.
but I realized then calculates a table I want to enoyer datas 8753b and block input error.
830 OUTPUT 716; "SING; Form4; INPUDATA;"
840 OUTPUT 716; Dat (*)
850 OUTPUT 716; "DATI; DISPDDM; CONT;"
c is by realizing this in labview from that I have a problem.
So how to send an array of data.?
good to you
Message 3 of 12
(4,152 Views)
I'm sorry but I don't understand what you want.
Your VI is just unreadable. The use of a stacked sequence structure (avoid at all costs) and the horrible wiring make it a mess. Why did you write your own code instead of using the existing driver?
Message 4 of 12
(4,146 Views)
I'm sorry but I know nothing has labview and therefore can not really understand tt and do well. that is why I'm here lol
I'll try to do better and come back after with some more things correct.
Message 5 of 12
(4,141 Views)
Use Help>Find Instrument Drivers.
Message 6 of 12
(4,138 Views)
Have you made any progress or are you still stuck?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 7 of 12
(4,112 Views)
I want connect to 8510A .
I know that, these are the error correction coefficiects created during calibration (also called a \cal set"). The error coefficiect arrays can be read from or sent to a computer, by the OUTPCALC and INPUCALC commands.
I can do saving a cal set to a file (save to pc),
but when I want recall a file (the same one that is saved to my pc) from pc and save to a cal set, vi. do not work.
system gives an error : "BLOCK INPUT ERROR"
I do not know why is it?
Yasamin
Message 8 of 12
(4,036 Views)
Hello Yasamin,
This does not seem to be linked to the original post.
Can you repost your question as a new seperate forum post?
Kind Regards,
Message 9 of 12
(4,026 Views)
ok,
thanks
Message 10 of 12
(4,017 Views)
