problem with reading the serial port
Though even the program work put some more time 300ms or 500ms.
Labview is amazing.
Message 11 of 17
(1,474 Views)
OK.
Thank you
Gustavo Carlos da Silva
PROBES - Engineering Solutions - Brazil
Message 12 of 17
(1,467 Views)
Good morning,
my problem with serial communication seems to be similar to the one of gustavo carlos but it has not been solved with a simple delay.
I try to get continous information of an eletronical load HDT ML50 (µload) every second (minimum)
As you can see the program sends the string "TA000000" serial, what means to "Tell All" Values of the electronical load, consisting of current, voltage and power of the load. The command has to be closed with return and linefeed.
The problem: the values are readable but after a while the communication is lost, the program only gets a "?". After more time communication continues.
I nearly tried everything to solve this problem but I obviously do not understand the communication.
Do you have any hints or advice?
Jonas
Message 13 of 17
(1,438 Views)
I´ve forgotten to add the vi, but here it is now.
I have added the random function to simulate a not constant intervall of measurement (caused by the code in while loop)
Message 14 of 17
(1,425 Views)
move the open and close outside the loop
It is also not needed to have a sequence frame around the read and the write. Keep the sequence frame around the wait !
This probably helps a bit
Another option is just to ask for 11 bytes (or a bit more) and have endcharacter enabled and defined
greetings from the Netherlands
Message 15 of 17
(1,410 Views)
open close outside
Message 16 of 17
(1,409 Views)
thank you for help but in fact it´s not the solution. Maybe it is caused by the instrument`? It has an internal serial to usb converter. After a while the connection is lost if timing intervall is not constant, everytime! In my opinion the handicap is the internal converter.
Message 17 of 17
(1,401 Views)
