problem with dev cpp
Check in your compiler' settings if there is something about a compatibility mode for your linker.
You could also load the DLL dynamically if you know how to do it. If you don't, I invite you to click on this following link : DLLs the dynamic Ways
This is for MSDN but you should find something similar for GCC. There it is a useful link : Linking Windows dll with GCC and do the Explicit Linking stuff because we do not supply a gcc compatible import library for static linking.
Do you have the possibility to use MSC? If you can, you would have access to a free compiler. And It would avoid you to load your dll dynamically. Try a free version : MSVC Free Version (There is a command line version if you prefer).
I would like to know why you have decided to use GCC on a 32bits Windows system?
Jérémy C.
NI France
Message 11 of 18
(1,741 Views)
i used to think that in order to call a DLL you must use a static library (.lib) on your project. That's what i'm trying, i m not looking for a static linking. Do you mean i 'm doing wrong (ie including a .lib file to call a .dll file)?
I will look at your links and tell you
i have installed visual c++ express 2010, i will also try with it.
i have previuolsy used DEVCPP to make a GUI associated with GTK+ and it worked fine. And i have never studied MVC That's why i choosed this one.
Many thanks
Message 12 of 18
(1,738 Views)
In my past projects, I always called .dll files to use functions written in it. That is the way used by MVC. I think there is a significant difference between using GCC under Windows and under Linux. Maybe under Linux, calling .lib could work.
Once you have learned to use MVC, I think you will prefer using it. Good luck.
Jérémy C.
NI France
Message 13 of 18
(1,729 Views)
Good Morning Jeremy
i 've tried this morning with MVC and it compiled fine
Indeed it seems easier with this compiler. Very interesting the links you gave me yesterday, i have learned a lot about DLL.
Now next step is to find right functions that match my needs and to test with the PCI card.
Thank you very much and read you soon for my next problem 😉
Message 14 of 18
(1,723 Views)
I'm glad to hear that. I hope that everything will be fine.
Have a nice day.
Jérémy C.
NI France
Message 15 of 18
(1,721 Views)
Thank you JEremy
i just have a little problem. In my project made with DEVCPP, i use a gpib link with a gpib-usb-HS from National Instrument and it works fine. Now i am migrating my application code on MVC i have a problem with the linker
Erreur 1 error LNK1104: impossible d'ouvrir le fichier 'gpib-32.obj' C:\Documents and Settings\xxx\projet_gtk\projet7\projet\projet\LINK
But i have put gpib-32.obj in the project properties dependencies: (in french proprietes du projet\dependances supplementaires)
Do you know what is missing or happens?
Many thanks to you
have a nice day
Message 16 of 18
(1,718 Views)
Usually, you have to open a new post to ask a new question. Moreover it's not really a problem relative to NI products. But I will try to answer to your question for the last time:
Here some links of forums where people met the same problem as yours and there are some solutions proposed:
Link 1
Link 2
Link 3
Link 4
Link 5
But I think that the problem comes from the spaces in the path of your file. This link will give you more information : Spaces in the path
Even I think that the last link will be the solution to your problem, I suggest you to glance at the 5 other links.
Try google for this kind of problem.
Regards
Jérémy C.
NI France
Message 17 of 18
(1,715 Views)
in fact i didn't put the path of the gpib-32.obj file in the library directory.
thank you very much and have a good week end
Raphael,
Message 18 of 18
(1,713 Views)
