problem in serial read
Hello everyone,
I am using Basic Serial Write andRead.vi from the example for serial communication with target. when I try to write AT command (AT\n) its reading the same AT command(AT\n) instead of OK.My COM port is working fine.. I tried in hyperterminal its working fine. can anyone tell me the solution. thanks in advance..
my labview version is 10.0
Thanks & Regards
saamy
(3,141 Views)
Hyperterminal always adds CR/LF to a command.
You wrote AT\n
Is your string display in \code mode or in normal mode and maybe change the basic serial write (inside) that always CR/LF is added before it is written.
greetings from the Netherlands
(3,117 Views)
Hi Albert,
Thanks for ur reply..ya was displayed in normal mode only. But now the problem is solved. I just used \r\n instead of \n alone after AT. now its working fine thanks a lot..:)
(3,110 Views)
