poor performance of NI-GPIB-USB-HS under linux
I have a linux system with two GPIB interfaces on it, an old  PCI-GPIB (rev 01) and a brand-new USB-HS.  Running a test code that communicates with a well-tested GPIB instrument (a CAMAC crate controller) shows that the old PCI board is 10 times faster than the USB-HS for a simple repeated write operation.   The system does support USB2; diagnostics do not return any errors for either interface.
Details:
up-to-date gentoo box,   2.6.19-gentoo-r5 kernel
c code, gcc 4.1.1 compiler.  Relevant code is:
        for(i = 0; i < count; i++)
                data[3]=i%256; data[4]=(i/256)%256; data[5]=i/(256*256)%256;
                ibwrt(cc12,data,6); /*typical camac write data*/
        tend();
        t =  tval();
        printf("%d calls to tend() = %2.6f seconds\n",(int)count,t);
a few lines of dmesg output:
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
hub 1-0:1.0: USB hub found
Initializing USB Mass Storage driver...
usb 1-3: new high speed USB device using ehci_hcd and address 3
USB Mass Storage support registered.
USB Universal Host Controller Interface driver v3.0
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
Symbol usb_register_driver is being used by a non-GPL module, which will not be allowed in the future
Please see the file Documentation/feature-removal-schedule.txt in the kernel source tree for more details.
Symbol usb_deregister is being used by a non-GPL module, which will not be allowed in the future
nipalk: no version for "nNIKAL100_getTimeOfDayInterval" found: kernel tainted.
ACPI: PCI Interrupt 0000:01:04.0[A] -> Link [APC1] -> GSI 16 (level, high) -> IRQ 20
usbcore: registered new interface driver ni488
(3,067 Views)
This result does not surprise me.  Unfortunately, USB is going to have much higher latency than PCI will for such small byte transfers.  The GPIB-USB-HS will peform on par with the PCI-GPIB when doing high byte count transfers.  National Instruments will continue to make the USB latency better, but faces the real world limitations of USB.
Craig A
National Instruments Engineer
(3,054 Views)
