phidgetsAnloge
 Dear all ,
I am using phidgetanloge module to control dimmer. i used the example program  for the anloge module from labivew. In each first run the labview program works perfectly but when i stopped and tried it again the programe didn't recoginse the hardware. I have to restrat my all prgramme to get it work. Is there any one who can help me with this.
Thank you.
bstar21
(3,042 Views)
Unfortunetelly we don't have a driver of your hardware. But what we think is that your refrence cannot be localized with LabVIEW. I found some info about phidgetsAnalog and LabVIEW which is maybe useful.
Phidgets - LabVIEW Library
March 07, 2011
Extract the folder called "Phidgets" from the zip file to any location you want.
\Phidgets\Library directory contains Phidgets Labview library functions.
\Phidgets\Examples directory has various examples. We DO NOT recommend dropping examples into user's programs as sub-VIs. These examples are designed to demonstrate how to write user's own VIs only. Please also keep in mind that these examples might be designed by using different Phidgets hardware from the users. There will be a great chance that these examples are not executable or partial executable. Please refer to the product manual for specific functions supported on the user's own Phidgets hardware.
We also DO NOT recommend modifying any VIs from the folder. User can always make a copy in a different directory for different Labview versions.
There are 2 ways to call the Phidget Labview Library:
   1)  Store the folder anywhere and copy and paste library functions from the folder;
   2)  Call from the Labview function palette (Recommended). User needs to do the following:
 i) Open Labview and select "Tools" -> "Advanced" -> "Edit Palette Set...";
 ii) The "Edit Controls and Function Palette Set" will appear. Right click on the free space of the "Functions" palette, and select "Insert" -> "Subpalette...";
 iii) Select "Link to a directory". Choose the "Phidgets" folder and select "Current Folder". (If it's a 64-bit, choose the "PhidgetX64" folder instead.);
 iv) Select "Save Changes" on the "Edit Controls and Functions Palette Set" palette and all Phidgets Labview functions will appear on the Labview function palette;
 v) For a more detailed illustration, please refer to the Phidgets Labview Manual "2.3 Installation".
For more details, please refer to the Phidgets Labview Manual or Labview Manual.
By checking the link below you can find different documents under LabVIEW section which are included all info about LabVIEW and phidgetsAnalog.
http://www.phidgets.com/programming_resources.php
Good luck
(3,025 Views)
