pda module error -200428
I am starting with the programming module pda with a simple acquisition program through the usb6008 and labview 8.5. The program I am still trying to run in my computer but mark the following error: <err>Value passed to the Task/Channels in control is invalid. Error code:-200428
If anyone can helpe me a little
thanks in advance.
(3,794 Views)
Someone could guide me please?
(3,776 Views)
Apologize for my mistakeSmiley Tongue, I not looked this error in the forum and there are lots of interesting information. Now I have changed NI-DAQmx to NI-DAQmx Base, and the examples of Labview run. But now I have a small problem,  I have created  a vi's and in the task/channel in control that goes to Start task, show me the task only of Meas&Automation, but not those of NIDAQmx Base Configuration utility, and therefore it is not possible to acquire data. I looked information on the subject and and I can not fix it. Can someone help me?
(3,743 Views)
I am no expert, but I think if you use a task constant and then type in the name of the task that you created in the task configuration utility, it will work.
mstudio
(3,718 Views)
Thank a lot  mstudio, what you say is correct, and I could fix it. I'm starting with this PDA Module, and there is difference with programming in LabView, there are many details that need to be careful, even in this link I found the answer.
[9/8/25 broken link removed]
thanks and greetings.
teresa
(3,707 Views)
