oscilloscope configuration problem
Hi all Labview user ! i'm just a student and starting my self study in labview ! i faced some problem that while i try to trigger Lightning impulse from DSO6052A scope but when i started my VI i can't control everything on scope and can't get 100% those waveform value to my computer !
need some recommend from all of u !! my English not too good
best regard! thanks
(2,841 Views)
Accepted by topic author Techly.K
I would start by moving all of your configuration to be before the loop.  Then just have the read inside.
With some oscilloscopes, I had to add delays between some settings just because the instrument needed that time to do the setup and ignored any commands I sent in that time.  So you could experiment with adding some delays between configuration VIs.
(2,824 Views)
yep many thanks brother !! i'll try it !
(2,814 Views)
