one loop of two parallel not running
I try to build a double loop structure. One loop runs the serial communication. The other runs the control components.
When I highlighted the running of the program, I found the loop with serial communication not running.
Can anybody help me with this issue?(Photo attached)
(4,905 Views)
From what I can tell you have 3 loops.
(4,886 Views)
You have a data dependency between the top loop and the bottom loop so the bottom loop will not run until the top one finishes. Basic dataflow.
(4,879 Views)
I want you build such a pattern in which one loop runs COM driver, data TX℞ The other one doing the data processing.
Currenly I made COM and processing in one loop, the COM doens't runs stably (error sometimes)
What is your advice?
(4,872 Views)
You need to first break the dependency. Pass the data to the processing loop via a queue like the producer/consumer architecture. Fix the serial read to eliminate the Bytes at Serial Port and the sequence structure. Neither are needed since you have enabled the termination character.
Provide the make and model of the instrument and attach the programming manual.
(4,866 Views)
Hi , thanks for solution. The error doesn't come (whether the same error will never come, let's see).
Thank you!
(4,841 Views)
