ni488.2 pci card does not find instruments
I am using a PCI NI488.2 card to interface with my instruments over GPIB. The interface suddenly stopped working.
While trying to debug I've determined the following things --
1. The hardware isn't at fault. I changed the PCI card and the problem persists.
2. Using measurement and automation explorer
      2a. Scan for instruments returns "no instruments found" when I shut down all instruments. This is okay.
      2b. Scan for instruments returns nothing found when the instruments are on.  This isn't good.
I have simplified the setup to a single instrument that I know has a functioning GPIB system (tested on a different computer) but the problem persists.
I did reinstall the drivers previously. The interface worked just once after doing that but it stopped working soon after.
Any solutions / suggestions?
(3,392 Views)
Found the problem. One of the cables was bad and was making the devices throw errors.
(3,387 Views)
Hey gauravbahl,
Glad to hear you were able to fix your problem! Thanks for posting your solution as well Smiley Happy
Justin E
National Instruments R&D
(3,362 Views)
