make install on suse linux 10 cannot compile nikal.c to nikal.o source & gcc ok
Hi Jason
No I have NOT been using 64 bit suse! I only tried this out of frustration.
I will now try 9.1 suse.
I have access to many computers.
We  use KDE. Are you using Gnome?
Yours Ian A Peden
Message 11 of 13
(1,533 Views)
Hi Ian,
We have tested the driver to work with 32 bit SuSE 10.0.  I had recommended that you try it on a clean, standard install of SuSE 10.0, have you tried this?  This is to be sure that there aren't any old conflicting drivers or anything.
We also support SuSE 10.1.
-Jason
Message 12 of 13
(1,525 Views)
Hi Jason
Please accept my heartfelt appology!
I have accidentally downloaded Ver 2.3 of GPIB Software, renamimg it Ver 2.5!!!
The 2.5 Software installs (nearly) flawlessly!
There are a number of points however:
  1. The Licence Display Hangs. Easily fixed I know..........
  2. Exactly the same USB / Inline  fault was fixed , in Ver 2.3 using suse 10 by  Rosholm. See the Thread.
I hope this does not put you off answering these threads!
  Yours A very Red Ian A Peden
Message 13 of 13
(1,520 Views)
