02-18-2011 11:34 AM
Hi Antonio,
It did not work for niether of 350. German engineer deteremined it could be becuase of 350-S but later on when I received different control unit it was the same case. They tried to send me various DLL files and asked me for text logs when I was trying to establish communication each time. But nothing worked in my case. Finally engineer from Germany gave up.
Rupesh.
02-18-2011 11:36 AM
So I received the 80Mb toolbox
after having contactd the Testo (from the german site).
So the dll problem I had before is now resolved.
The premade vi example to acquire a measurfement doesn't work but I have noticed that the initialization vi
for my case (usb connection to the pc) did work.
So I create my vi for the acquisition using the initialization premade vi.
Finally I can communicate and acquire the data.
To make the vi myself I studied a bit the way it is done the premade vi coming with the toolbox (the vi that I tried at the beginning and did not work).
From there I found out how to retrive the data after initialization using th eactivex control.
Thank you all for the help
09-04-2012 04:23 PM
Hi all,
sorry to bring up this old post but i desperately need the testo toolbox. I'm trying since July to use my Testo 845 with Labview, without any success. I must say that support from Testo was quite poor, some of my e-mail were ignored at all. Now I read that there's a full version of the Testo toolbox (the 80 mb one), obtainable only on request. I bit disappointing in my point of view.
Can anyone send me the file? I would really appreciate your help.
Daniele
09-06-2013 10:27 AM
I'm curious about this; I've used Testo combustion stuff, and now may have to use the Testo 560/570 (for refrigerant analysis) with Labview.
Sounds like support might be a bit sketchy.
A.
09-06-2013 10:47 AM
Extremely poor suppot from Testo about Labview. Initially local dsitributor cliamed that combustion analyzer can communicate with Labview. When I recieved the toolbox none of the serial initialization VI's in toolbox could talk to Testo 350-XL. Nobody in US or Germnay could tell me what serial commands are needed for the instrument. I struggled with it for few months.
I do not know about other Testo models.
09-06-2013 11:45 AM
Bleah. How did you get the full toolbox, BTW?
09-06-2013 11:51 AM
I requested it from US office and received a CD. This was couple of years ago. It used to be on their downlaod center as well. Try the following link.
RS.
09-06-2013 12:22 PM
Local Testo seller just sells them; no tech support. If you can pass on the contact, that would be great. Trying to get technical help from Testo seems tough.
Website doesn't show any full toolbox.
09-06-2013 12:55 PM
To get the full toolbox you have to request it via support. Some years ago they gave a "private" link to download the toolbox. As I have already writen, even with this toolbox my analyzer didn't work. Some Testo engineer in Germany (I don't remember how I got his contact) had to make new dll's to suit my needs.
Try to get in touch with someone from Testo who agnoleges that can't help you and then he/she will get you in touch with someone who really can help you!
11-11-2013 05:00 AM
Hello 🙂
I am trying to connect a Testo 435 and it uses USB port connection to the PC; does it make any difference with the serial measurement example given in the toolbox? since I do not have COM port number.
I don't know very much about ports and data communication speeds.
Thank you!
