klp 75-33-1200 Power Supply - Programming
Hello I am having issues with the programming with KLP power supply with GPIB connection and scpi commands. In the IV set main VI, I set the current and the voltage values but It doesnt read the curr and voltage values and gives a receive error. However, when I only use write and read files I dont have any error. You may see the files on the attachment.
(3,222 Views)
You ask a lot of bytes and I'm not sure that the endcharacter is correct.
You did not add the global so we can't see all, and I don't have the description of the instrument.
But I found LabVIEW drivers on the Kepco site
I used LV 7 to make them readable in higher LV releases and attached it.
Looks good but I cannot test it.
greetings from the Netherlands
(3,216 Views)
