03-30-2010 09:30 AM
I created new instrument drivers in the .lvproj library but when I tried to use those driver VIs they don't appear on the palette menu. How do I fix this?
03-30-2010 01:40 PM
03-30-2010 02:27 PM
To answer your question, I'm not really sure. I'm confused. I thought I placed the drivers in the instr.lib but it doesn't seem that way. I've attached the file.
I want to upload the drivers in this project to the palette menu.
03-31-2010 08:00 AM
Hello Mbdeck,
The recommended way to create a new LabVIEW Plug and Play instrument driver is by using the Instrument Driver Project Wizard. The wizard generates instrument driver code that gives you a starting point for development. The VIs that it generates already show up in the pallets also.
To edit the pallets, go to Tools>>Advanced>>Edit Pallet Set
Cheers,
NathanT
03-31-2010 09:52 AM
Hi Nathan T,
I started with the instrument driver project wizard. When I tried to name the project, an interactive window popped up saying that a similar name exists and it didn't allow me to save the project as "oscilloscope project" so I had to change it to OSC as you can see in my earlier attachement.
Just to give you the full picture, I had done this exercise before but with an evaluation copy of labview 8.6 without problems and the evaluation software has already expired. I'm now repeating the same exercise with labview 2009 that I recently purchased and installed on the same computer. I don't know if this has anything to do with the current issues I'm having but I just want to mention it.
Anyways, everything seemed to work well and I was able to create and edit VIs that came with the project. I only started having problems when I tried to build an example VI using a "configure" driver I created. I couldn't find that driver under the configure sub-palette for the "OSC instrument driver" palette eventhough the driver exists in the project.
03-31-2010 06:25 PM
Hi Mbdeck,
I just walked through the Instrument Driver Wizard in LabVIEW 2009 SP1 and it seemed to work for me. Is it just the configuration VIs that you are missing in your palette or are there others missing as well? I tried using your files, but with only the .lvproj files posted I could not use it in my instrument library, it requires the .lib files as well. This could also be your issue if you were copying it over from a different version of LabVIEW. You will need a folder inside of the instrument library with both your .lvproj files and your .lib files.
03-31-2010 07:09 PM
