installing ni488.2
When trying to install the GPIB-ENET/100 software
on a Win2000 PC, I get the following error box:
Currently installing NI-PAL 1.5.8f0 Engine. Part 2 of 4
Removing backup files
File: C;\config.msi\abf1213.rbf
Error 1605 occured while installing NI-PAL 1.5.8f0 Engine
(4,014 Views)
Error 1605 is usually a disk space error. If disk space is not the problem, the error was generated by a corrupted installation/uninstallation of that product in the past. Continue installing other products. After the installer finishes, browse the CD and go into the folder of the driver that failed during the installation. Run the individual installer for each driver that failed.
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(4,014 Views)
