‎02-27-2012 04:40 AM
I have an application that uses a hp34401, a CVI dll is used to control the instrument for AC & DC voltage measurement & 2 wire resistance m/ment,.
The instrument is used in the 8840 language mode, does anyone know if there is any significant performance / measurement speed improvement by changing the programming mode to SCPI language?
‎02-27-2012 07:22 AM
‎02-27-2012 10:34 AM
More importantly you gain code compatability with other DMM's that have the same SCPI command interface, so can easily substitute DMM in the future if you ever need to.
