hp 4145B instrument driver problem
I am having a problem with the graphics plot.vi program of the hp 4145B instrument driver library I downloaded from NI network. This Vi calls a sub vi which is data output.vi and this particular subvi is unable to send its data to the computer. Only in case of short integration time (i.e. the instrument takes measurement very fast and it is not worth always), the dataoutput.vi is able to write if the time out (in ms) is large enough. However I would like to get the data out for a larger integration time, so that the data is good enough. And although this subvi works, this is unable to send its data array to the graphics plot.vi and I get an error message from graphics plot.vi saying error with receive message problem. Could anypne help
me with this?
(3,192 Views)
It sounds like you just need to adjust your timeout. Open the initialize VI and increase the timeout in the block diagram, the original values is set to 10000ms.
(3,192 Views)
