how to unload DLL
I am using LV 8.2 to call a DLL but I am facing a unload DLL problem:  the result can not be cleared from the memory even after I closed the VI.  Only way to unload the DLL is to shutdown the LV.
I was told to using VI server to call a subVI which deals with the DLL.  But for our application, using VI server seems not practical.  Anyone has a better idea to solve the problem?  Thanks in advance.
---Julia
(3,923 Views)
You would have better luck getting an answer if you posted to the LabVIEW board instead of the instrument control board.
(3,920 Views)
Thank!  ...
(3,915 Views)
This is a duplicate post. See this thread for work on this issue.
Missy S.
Project Engineer
RoviSys
(3,893 Views)
Thank you very much, MissyD.....  I did not know it could misleading to viewers.
(3,875 Views)
