how to acquire all TM from oscilloscope DPO7104 in a txt file ?
I would save TM from oscilloscope (rise time, fall time, Vhigh....) in a txt file.
I work with a Tektronix DPO7104 but i don't konw how to acquire all the telemesures in txt file via Labview 2012.
Could you help me please ?
thank you
(4,748 Views)
Accepted by topic author BOTTEROC
If you go to Help> Find Instrument Drivers, you can find and install a project-style driver for the instrument. The different measurements can be written using a function like Write to Spreadsheet File after you create an array from the measurements.
You haven't attached your code or a snippet so it's impossible to say what is wrong with what you have tried.
(4,746 Views)
Thank you for your message.
I have downloaded the last version driver of the oscilloscope and i found lot of example on the web.
I try to do what i want.
best regards
(4,717 Views)
You can find a lot of examples with Help> Find Examples including ones for the instrument and for saving text files.
(4,710 Views)
ok thank you
(4,707 Views)
