how do I communicate with an instrument over ethernet?
Hi all,
I wish to communicate with a Rohde and Schwarz ZVK vector network analyser over ethernet, Can somebody briefly explain how this is done?
many thanks
(3,836 Views)
The best you can do is search on IDnet
http://www.ni.com/devzone/idnet/
and if the device driver ( a bunch of vi's and examples) is available use it as an interface.
Ethernet is a communication channel just as rs232 and gpib, only a bit cheaper and faster than those.
greetings from the Netherlands
(3,826 Views)
I'd also like to add that you should go into MAX and in the configuration pane, right click on Devices and Interfaces, and select Create New>VISA TCP/IP Resource. Once that has been configured, then you should be able to use a driver or your own VISA functions.
(3,823 Views)
ah great! Smiley Happy
thanks very much
(3,820 Views)
Can someone please let me know how can I make sure that my PC is communicating with MKS MFCs in Labview through RS232?
(3,807 Views)
Since your question has nothing to do with communicating to an R&S instrument over Etherenet, please post your question in a new thread. Provide additional details like LabVIEW version, error codes that you get, etc.
(3,795 Views)
