hi, i want to control my vi from multiple systems using ethernet options can any body tell me how to do that? thans in advance
(4,504 Views)
Have you looked at the web publishing option and using a remote panel? Look it up in the help.
(4,484 Views)
actually i want to control my programme which is in another computer with my computer with out going to that computer.
(4,471 Views)
check out vnc
perfect tool to control another computer from your place
greetings from the Netherlands
(4,464 Views)
There are multiple ways of doing this. Here are some of them..
The Web Publishing tool allows you to publish the front panel and you can control the front panel remotely. https://www.ni.com/en/shop/electronic-test-instrumentation/programming-environments-for-electronic-t...
The TCP/IP socket can allow you to pass codes "strings" to another computer. Lookup the server client example.
regards,
Gautham
(4,378 Views)
