hardware?
Hi all,
I am working on a new experimental set up for my thesis and I want to control the whole process using LabView 8.
The set up has two chambers each one connected to a capacitance manometer (http://www.mksinst.com/cgi-bin/product.exe?pid=626a) and,  4 solenoid valves (http://www.mksinst.com/pdf/HPSEMCvDS.pdf) to control the flow.
My goal is to open the valves when the pressure reaches a certain value in each chamber using LabView.
So far I have ordered the valves with 24v DC solenoids (1.3 A initial / 0.3 A running) and an external power supply for all of them. For the capacitance manometers I have ordered a Digital Power Supply (http://www.mksinst.com/pdf/Pdr2000ds.pdf) with an Rs-232 interface.
I am very new to LabView and I am not an electrical engineer.
I don't know what hardware I need to connect the valves and the manometers to the PC.
Any suggestions?
George.
(3,608 Views)
For the solenoids you can use a relaydriver ER-8 from NI that can be attached to a usb 6009 or cheaper digital/analog interface
for the other hardware you need a rs232 port on your pc (built in or via a usb hub)
succes
greetings from the Netherlands
(3,596 Views)
Thank you Albert,
This looks like a simple and inexpensive solution. I'll look into it and get back if I have questions.
Best Regards,
George.
(3,584 Views)
