gps
Hi.
Anybody have a program that read GPS Time, Position, Velocity, and Course Heading? As i am currently using version 7.0, i couldn't open the sample done by the support group
(4,763 Views)
I assume this is the example you are talking about. I've saved it for LabVIEW 7.0, so you should be able to open it now.
Thanks.
Ebele O.
(4,744 Views)
I'm using USB interface abd LVB 8.2. So how can I do to read Time, Position.
(4,530 Views)
I'm not using interface cable pc. I'm using USB port.
So can you please tell me how can I do to read position GPS form USB. Do you have VI to do that.
(4,517 Views)
Hey Mora,
Most of the USB manufacturer's have devloped a driver that maps a USB port to a serial COM port. Once it is mapped, you can use this current example program right away. If you don't have the driver, then you would have to analyze, and understand the device, and manipulate the program in order for it to work.
Nick D.
(4,495 Views)
