gpib
hi!
i have a probleme with the card 82350 PCI GPIB.
when i use in labview VISA find resourse labview recognized the card and gives him the addresse GPIN::10::INSTR,
but if i do a program for reed the data with VISA read i have this error: -1073807339.
i already did all the configuration and i install this labrary : IO librearies suite 14.2 and i did the unististall for all IN-VISA.
what can i do?
thnaks
(3,193 Views)
Not really sure if uninstalling NI-VISA was the correct thing to do. I think you should NI-VISA installed and enable the tulip passport.
In any case, you have a timeout error. What that usually means with a GPIB instrument is that that you are attempting to read when there is no data available. You don't mention the instrument or the commands you sent. That's important information that needs to be provided in order to help.
(3,182 Views)
