gpib with visualfox
is posible to use visualfox to adquire measure using gpib
i do it with rs232 on a agilent 34401 and it's so easy to control and adquire a measure but i have problems with GPIB
Message 1 of 10
(6,230 Views)
Moved from LabVIEW board.
What is visualfox?
Message 2 of 10
(6,215 Views)
is a database program and is easy to build a aplication when you need to do several measures and recor or compare the measures and you need to configure same time a instruments but i have problem to conect the program with GPIB
Message 3 of 10
(6,208 Views)
You mean FoxPro. That hasn't been a product for several years and I doubt that NI supports it any way.
Message 4 of 10
(6,202 Views)
https://msdn.microsoft.com/en-us/vfoxpro/bb190225.aspx
If it supports VBA, then you would be able to control GPIB with it.
Message 5 of 10
(6,177 Views)
actualy i'am trying to use CWINSTR.OCX or CWVISA.OCX to control a gpib card and visul fox accept them.   the problem is i dont have a full of them and i am using a demo
Message 6 of 10
(6,135 Views)
Accepted by topic author diazomar2004
We can't help with that. BUY the software.
Message 7 of 10
(6,119 Views)
actualy in my  job wue have labview 9 and they wil buy the software but i am trying to save time
thanks for all
Message 8 of 10
(6,106 Views)
thanks for all
I could be wrong, but those OCX files don't come with LabVIEW 9.
I also don't believe there was ever a LabVIEW 9 unless you meant LabVIEW 2009.
Message 9 of 10
(6,100 Views)
Complete waste of time to try and use the ocx files. You should at least attempt to use LabVIEW.
Message 10 of 10
(6,093 Views)
