gpib not responding
I have vb6 sp5 and NI PCI-GPIB board
My program:
Private Sub test()
Dim data1 As String
Call ibdev(0, 12, 0, 10, 0, 0, 0)
Call ibwrt(0, "TF\n")
Call ibrd(0, data1)
MsgBox (data1)
End Sub
I give the same command to the IBIC there is no problem
Is anything wrong in my program ?
Thank you for Help
(4,074 Views)
My program:
Private Sub test()
Dim data1 As String
Call ibrd(0, data1)
MsgBox (data1)
End Sub
Thank you for Help
The first parameter of the ibwrt and ibrd calls should not be zero. They should be the return value from ibdev (In VB, this is the last parameter passed to ibdev). Therefore, you need to change the last parameter of ibdev to be a variable and pass the variable as the first parameter of ibwrt and ibrd.
(4,053 Views)
Hello Gpib Guru,
I tried it but its the same
dim ud as integer
dim data as string
data = space(20)
ibdev(0,12,0,10,0,0,ud)
ibwrt(ud,"TF\n")
ibrd(ud,data)
msgbox(data)
there is nothing in data and NI Spy give me a EABO(6) error
(4,032 Views)
Can you attach the NI Spy output?
(4,028 Views)
Try increase the timeout value so the device has more time to respond. Code in IBIC executes slower than VB because you have to type in the commands, this gives the device enough time to send back data.
(4,020 Views)
Hello Guru,
I tried with a another buttun click to read from device but here are the messages from NI Spy:
with command: ibrd --> 0x8128 EARG(4)
with command: receive --> 0xC164 EABO(6)
there i no problem with ibwrt or send...
THX
Tuy
(3,983 Views)
hello,
THX everybody...I can communicate with the device
my send string was wrong
send(0,12,"TF",1)
(3,977 Views)
