get waveform agilent source 6812b with labview
Hello everybody, I'm trying get current and voltage waveforms of a electric circuit with some loads with a agilent 6812b source. For that, I have built a program in labview(attachment) and I get good results because sending the command "MESure CURRent ARRAy" I get it as a text file(the another attachment). Well, my problem is that I am not able to save results in a excel spreadsheet. I have tried it several times but I have not been able to get it. It is because Agilent source make 4096 digitized measurements of current and voltage, and after that, the source send to Labview all digitized measurements together. For that, when I try to save them on a spreadsheet of excel it's imposible. Can anyone help me?, Thanks.
(4,212 Views)
Excuse me, I forgot the attachements.
(4,211 Views)
Hello of new. Why anybody helps me?
I want to say that I have alredy solved the problem. The problem was that I didn't understand how Agilent source works. When I send the command, the source measures all data digitized points, and after that, it send to PC 4096 digitized points(it lasts 100ms working at 40kHz).
But now, I have another one problem, Labview doesn't receive all digitized points, it only recieves about 1700 points of 4096 that it should receive. I has been searching on the internet and I have alredy put the termination character off but I continue whit the some problem.
Please, help me!!!! I'm crazy and don't know what can I do. I put here my VI for all you can see it and help me.
Thanks.
(4,145 Views)
