framing error in rs232 using visa but not through terminal program...
Hi All,
I have an application (LV 8.6) which communicates with and controls a device over RS232. The application has so far worked fine. Today I tried it on a newer computer but I keep getting "framing errors" (-1073807253) now when I run the application.
The strange thing is that I can communicate fine with the device via a terminal program (using putty since hyperterminal is no longer present on windows 7). Could it still be a hardware related issue? Why would putty be ok but visa struggle?
Any thoughts or suggestions most welcome!
Paul
(3,600 Views)
Hi Paul,
There are a couple of reasons Error -1073807253 can occur when making use of NI-VISA for serial communication.
KnowledgeBase Article - Error Code 1073807253 When Using VISA Read specifies that this issue could be occurring due to a misconfiguration of the port buffer causing trouble when performing a Read operation. This specifies that by forcing a small wait directly after setting up the buffer and then using the VISA Flush I/O VI to remove any malformed configurations that could exist in the buffer, a reliable channel of communication can be defined for your serial instrument.
I would also suggest ensuring that you have the latest version of NI-VISA installed.
Please let me know if the helps!
Kind Regards,
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
(3,585 Views)
Most of the time framing errors are caused by wrong communication parameters. Double check the baudrate, number of data bits and parity.
Kees
(3,566 Views)
