flush visa
hello,
i have troubles with an rs232 communication ( via usb adapter prolific) so i would like to be sure about what i do
because i'm begining to have doubts about everything and would like to be consolidated about some function:
flush function operate on PC I/O buffer or device buffer ?
what it is called input buffer ? the input of pc buffer or device buffer , it nearly the same question as above.
What is the difference between  visa read ( reading all present caracters )  and a flush input ? is that equivalent ?
same in the other direction what could be the equivalent to flush output (without sending caracters) ?
To specify my question, i wrote code that operate well since 2 month with continuous measurement sequence
, but now we ask me to provide code where sequence can be interrupted then resume, so i tried to manage
communication line with flush and wait function but troubles still appears
Thank you for your help
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,172 Views)
flush input means read but throw away the result, flush output, I'm not sure, I guess it clears the output buffer.
Anyway, your program should not send when requested and also if an input not appears andle the timeout gracefully.
greetings from the Netherlands
(3,169 Views)
