find examples for usb
please get me one example for visa and usb
(4,853 Views)
just do a search for example code on this dev zone. I searched for "usb visa".
http://search.ni.com/nisearch/nisearchservlet?nistype=default&ddown=3&filter=%2Btaxonomy:%22Example+Code%22&q=visa+usb
(4,842 Views)
How many bits can I acquire by usb port?
If it's 8 bits How can I acquire a string ( I don't Know if it's the name ) of 16 bits... I know that I have to split the string but how??? somebody can help me?
Another question is: when the ubs port acquire information it give me in what format? it's a string? Can I work with this strings or I have to convert to array...please I need this information...
Si alguien habla español seria muy bueno gracias...
Diego Andrés Orduz T.
Estudiante Ingeniería Electrónica
Grupo De Investigación CEMOS - Control, Electrónica, Modelamiento y Simulación
Desarrollador Proyecto de Grado As-Interface
Auxiliar Bienestar Universitario
Universidad Industrial de Santander UIS
Bucaramanga-Colombia
(4,659 Views)
What is the USB device you are trying to get data from? One of NI's USB data acquisition devices or something else? What function are you using to read? If the device is a USBTMC class, then you are probably using VISA Read and that returns data as a string. If you have a USBRAW device, then you are probably using VISA USB Control In for a USB pipe transfer and the data read is an array of U8.
(4,656 Views)
well I'm using a VISA read, I'm send a lot of bits to the USB por by a microcontroler ( It's a mine application ) but I not just have this problem ( string or whatever ) I don't Know if labview accept me 14 bits , I send 14 bits of my microcontroler to the USB port and the to labview , How can I take this 14 bits on lv?
(4,617 Views)
Hi Diego,
I saw you had a problem with a communication between a micorcontroller and PC trough a USB. Have you find a solution for this matter? I'm in the same condition, and I don't understand if it is possible to establish a communication via USB. I had a .vi in which I establish a comunication between LabView and microcontroller via RS232, but now I must work with a PC without rs232, so I've tried a USB-rs232 converter but it seem to work not well, in particular with high communication speed. So I'd like to know if I can do the same work with USB....please help me!!!:womansad: Smiley Sad
Cristina
(4,303 Views)
If you are using NI-VISA then you should have no problems communicating to your instrument. Infact you should be able to use the same vi that was working with straight RS232 communication and just change the port of communication. VISA will communicate threw either method.
Regards
Krista S.
Applications Engineering
(4,276 Views)
