esg
Hi all
using the ivi driver for E4438C in cvi I would like to configure the output frequency only.
The RF configuration API "agesg_ConfigureRF" requires both the freq and the level.
The only way of doing so is to use the "agesg_SetAttributeViReal64", if true how do I do so?
Regards Ofir
(3,395 Views)
ofirga--
I looked at the VI in LabVIEW, but I did not see a way to not provide a default power level.  For instance in LabVIEW, if you do not provide a value for that parameter it automatically assumes -135 dBm.  Just out of curiosity, why do you not want to configure the power level?
Hopefully others on the board can provide insight for this operation.
Tyler C
(3,361 Views)
Hi Tyler
Probably you miss understand me....
while setting the frequency and the level, now i would like to change only the frequency without altering the level, the driver does not support that (tho the ifr 2025 does)
so I need to maintain both values.
So I tried to use the "agesg_SetAttributeViReal64" command with a specific attribute but fail to do so.
My questions are: can I do it and how?
Regards Ofir
(3,344 Views)
