error 24
In an application from the vi "Bytes at serial port", I get error 24. No problem normally, but my error-handling depends on it.
Does anybody know what this means and how to get rid of it.
(3,244 Views)
The LV explain error 24 gave "...Warning 24 occurred at an unidentified location. Possible reasons: LabVIEW: Bad external code offset..." which is very helpful
The "Bytes at serial port" is old and I would encourage you to use VISA-serial instead. There are example VIs in LV that do serial comm. You can find them through the Help menu >> Examples.. >> I/O >> Serial.
Also hope you havethe latest updates from http://digital.ni.com/softlib.nsf/display?ReadForm&view=current&node=132060_US
(3,244 Views)
